I'm off to work with a smile on my face after reading those few posts..thanks guys!
Re: Cost of block-built garage, 24' x 10' ?![]() ![]() ![]() ![]() ![]() I'm off to work with a smile on my face after reading those few posts..thanks guys!
![]() Re: Cost of block-built garage, 24' x 10' ?
For once I'm going to say 'carry on boys"' ...never thought i would be interested in block building sheds! ![]()
Be carefull Ann you will be talking about "tyre thread pattern" and "boost pressure" next.
Re: Cost of block-built garage, 24' x 10' ?ahem....work away, work away....I ain't complaining...
![]() Re: Cost of block-built garage, 24' x 10' ?would agree with ollie re. width. my garage 11foot wide by 24, sorry i didn't make it a few foot wider. if you build a block garage don't forget depending on width and roof you may be able to have a loft for storage etc.
Re: Cost of block-built garage, 24' x 10' ?Anyone here know if the corugated galvanised sheets are still available to buy???
My workshop is 45 x 25, 3 link barn type but the sheets are starting to rot on the sea ward side. The perfection of a Car's beauty is that nothing should be there for beauty's sake.
![]() Re: Cost of block-built garage, 24' x 10' ?Most good hardware stores should be able to sort you out, try some of those "out in the country" co-op type places for farmers, bound to have 'em
This shed thread is going down the gutter tho' (see,even gutters come into it), erection,width,girth - all been mentioned - what next!?!?!? ![]() ![]()
![]() Re: Cost of block-built garage, 24' x 10' ?drain pipes?
![]() Re: Cost of block-built garage, 24' x 10' ?yeah ill try that John, i have'nt seen any new corrugated ones lately only the kingspan flat sheets. Cheers
http://www.donedeal.ie/for-sale/otherfarming/1031373 ![]()
![]() Re: Cost of block-built garage, 24' x 10' ?ah great stuff Olly, i may go a measuring, cheers.
![]() Re: Cost of block-built garage, 24' x 10' ?Question Stig. Was looking at shed such as yours sheeted to the ground but was advised to get one sheeted down to a block wall instead as there would be a chance of water getting in if sheeted to ground. Have you had any such problems with water getting in....I suppose (just for the ladies) does yours leak
you could, a course of 2 of blocks would be good, It's sommit I considered, but with good gutters and a fall each saide of the shed, I have no leaks. If you do this, advise the maker so he'd have to make the doors and entrance door a bit longer at the bottom etc... ![]()
Hola, not been on the site a while. Fwiw, I work here: http://www.sip-energy.com and I'll be building a new garage for myself in the late spring, using our panels. I say this based on (and I know some of you have seen/been in, my other garage). I currently have a 12m x 8m, conc block, fully insulated walls and roof, and 'leccy doors. Whilst good, and warmer than most houses, it ain't warm enough for me........ ![]() On the PP thing, you're correct. If it's over 25sq me in footprint, you'll need PP. The 'exemption' for 'temporary' structures has long disappeared. One caveat on all garages: is that a garage by itself won't protect your car. A car stored in a garage devoid of proper airflow, will, in fact, go 'off', quicker. Humidity, you see.......all that moisture will want to go somewhere, and little nooks'n'cranny are the perfect breeding grounds for tinworm. When I get the finger out, and have actually started, I'll post some pics. Quick! free up some money for your '5 buy an energy efficient house ! One swallow does not a Summer make....neither is it long enough to put your '5 back together....
