Cat by pass/ sensor wires......
Postby sidewaysreilly » Thu, 15 Apr 2010 2:12 +0000
Fitted a CAT bypass pipe yesterday amd wondering what to do with the sensor wire????????
Re: Cat by pass/ sensor wires......
Postby franksm » Thu, 15 Apr 2010 3:07 +0000
The after-cat sensor ?
Remove the sensor and tape the wires up away from harm, it's not needed any more.
Postby sidewaysreilly » Thu, 15 Apr 2010 3:41 +0000
Thanks Frank, was wondering what that sensor is for if its not needed???
Postby franksm » Thu, 15 Apr 2010 3:45 +0000
It's like a fuse - when the cat overheats, the sensor melts and that causes a lamp to light up on the dash. Removing the sensor leaves the circuit open, and light extinguished. It's just a lamp too, not connected to the ECU (on MK1s)
Postby Steve » Thu, 15 Apr 2010 4:19 +0000
Hmm.. so what could the spare wiring + lamp be used for.. ?
Low fuel, fog light, "lights on", alarm warning light, knock sensor.. ?
Hmm.. wonder if you could get the alarm warning led in there..
Aha!
Postby sidewaysreilly » Thu, 15 Apr 2010 4:34 +0000
Thanks lads, yeah my mind boggles with all the uses it may serve.
