Soft Top Replacement
Postby lucy » Thu, 14 Feb 2008 2:35 +0000
Hi,
The soft top of my 1998 Mk 2 car has started to leak.
does anyone know where I can buy a new roof and contact details for fitting??
Lucy.
lucy
soft top
Postby x5trebor » Thu, 14 Feb 2008 5:33 +0000
hi Lucy you can buy replacements and fit them your self I got mine replaced By Arthur in web cars in Bray it seems great have had no problems, see Link http://www.webcars.net/softtop.htm
x5trebor
x5trebor
Lucy
Postby robmx5 » Thu, 14 Feb 2008 10:47 +0000
I'm in the same boat at the moment. The price depends a lot on what type pf roof you want to fit and if your prepared or know someone that can do it for you. There are a couple of lads on here who have fitted them for other people - approx 6 hour job.
I am looking for a navy mohair hood.
www.mx5parts.co.uk currently have genuine Mazda hoods on special offer. Appox €750.00 delivered - then I have to fit it.
Art on webcars is charging approx. €1300.00 fitted.
Another site worth looking at is www.mazda-mx5-shop.com - there hood is approx. €520 delivered (not a mazda hood though)
A vinyl hood (normal) would be cheaper than all of the above.
I believe its a good idea to replace the tension cables at the same time. Genuine Mazda hoods are suppossed to be good for up to 10 years if looked after - which means mine is at the end of its life.
Hope that helps.
Robin
Postby Reesy » Thu, 14 Feb 2008 11:53 +0000
Hi,
There's a guy in Neath, Wales - Jack Smith Trimmers I think he's called. See here http://www.mx5ocforum.co.uk/viewtopic.php?t=41553 - seems to be good service. I think he will ship them too.
Simon
Reesy
Re: Soft Top Replacement
Postby Fergus » Fri, 15 Feb 2008 1:10 +0000
lucy wrote:Hi,
Lucy.
If your in Cork I can fit it for you, I've done a good load of em here for the Cork lads in the club already.
There are LOADS of hoods available out there but be sure to get a good quality one, the cheaper the hood then the more issues you'll have with it in the long term.
There's also SFT: http://www.jagspares.co.uk/mx5/company.asp
I got my Mohiar hood from them and it was a perfect fit.
As for fitting a hood in 6 hours, thats with taking short cuts and not using Evo glue/rivets etc for example.
If you need rubber seals etc then I'd go get them at less than half the price second handf from www.sniffydog.co.uk
Postby Fergus » Fri, 15 Feb 2008 1:12 +0000
(PS) Don't forget to get new cables while your at it:
http://www.mx5parts.co.uk/product_info. ... cts_id/451
New roof
Postby lucy » Mon, 18 Feb 2008 2:32 +0000
Hi Guys,
Thanks for the help, I'm going to start ordering later this week.
Fergus, I do live in Cork, I'm buying the cables and seals this week also.
Lucy.
lucy
Postby Fergus » Mon, 18 Feb 2008 3:37 +0000
Do you have somebody in Cork to fit it for you ?
Great value on soft tops
Postby Medic5 » Mon, 18 Feb 2008 5:18 +0000
Soft Top Fitting
Postby lucy » Tue, 19 Feb 2008 9:52 +0000
Hi Fergus,
I don't have anyone to fit it at the moment.
Lucy.
lucy
Postby Fergus » Tue, 19 Feb 2008 10:37 +0000
Seems a Cork Tech Day may be on the way.... :D
Window seals
Postby lucy » Thu, 13 Mar 2008 9:29 +0000
Hi,
I've received my mohair hood and tension cables.
I'm now ordering the seals - I presume I need to order 6 - two front, middle & rear. Am I correct???
Thanks,
Lucy.
lucy
Window seals
Hi,
Thanks,
Lucy.
lucy
Postby Sean » Sat, 12 Apr 2008 9:12 +0000
Hi Lucy,how are you getting on with your new roof? Has everything arrived and is it ready to be put in?
Sean og
Sean
Roof Seals - Help!!!
Postby lucy » Wed, 16 Apr 2008 9:00 +0000
Hi Sean,
I have the roof but I'm waiting to order the seals.
Do I need Front, Middle and Rear seals for each side?
Lucy.
lucy
