How do you identify a limited slip diff from others??
j
How do you identify a LSD.How do you identify a limited slip diff from others??
j
Re: How do you identify a LSD.Thanks for the interesting read Steve.
j
Re: How do you identify a LSD.look thro the fill/level hole. If you see 2 vertical worm gears with spur gears meshing them together, its a torsen type 1. If you see 2 horizontal worm gears its a torsen type 2. Stay clear of the viscous type. They are crap.
