![Confused :?](./images/smilies/icon_confused.gif)
Im not sure about the seals to be honest as i am totally in the dark on roofs
![]() Sean og
![]() What do you mean by 'front, middle and rear seals' Lucy ?
Are you talking about the big rubber seals that touch against the doors window/glass ? If you are talking about the rubber seals that touch the doors window then those seals usually don't have to be replaced when fitting a new hood. What is wrong with the ones you have now ?
![]() Hi Fergus,
They look a bit old but they are probably fine!! I'm no technical genius unfortunately!! Thanks, Lucy.
Well if your in Cork then I could check them for you, probably just need a clean to get them glossy again
Who is onlineUsers browsing this forum: No registered users and 5 guests | ||
