Moisture in boot
Moisture in boot
Postby landmarkjohn » Sat, 17 Dec 2011 10:02 +0000
Hi All, this is our second winter with a '98 MX5 and we notice a lot of moisture inside boot lid, sweating kinda like the back of the fridge. Don't remember it being like this last year. Only thing that has changed in meantime is a new roof. Do they all do this? Thanks
landmarkjohn
Moisture in boot
Postby mx5ash » Sat, 17 Dec 2011 10:06 +0000
Is the back parcel shelf wet? Check under the carpet to see if sound proofing is wet. Also could be leaking light seals, ariel hole. What type of battery do you have?
Re: Moisture in boot
Postby Reesy » Sun, 08 Jan 2012 11:46 +0000
My own boot leak problem was caused by the rubber around the boot lock barrel being missing so water came in thru the keyhole. Fixed it by sealing with silicone.
Simon
Reesy
Moisture in boot
Postby landmarkjohn » Mon, 09 Jan 2012 11:55 +0000
mx5ash wrote:Is the back parcel shelf wet? Check under the carpet to see if sound proofing is wet. Also could be leaking light seals, ariel hole. What type of battery do you have?
hi Ash, thanks for getting back, only reading this now... Battery is a regular lead acid type.... Is this bad?
landmarkjohn
