On Sunday I went for a little ride over to Ballyvourney for some airsoft. On the way home, the clutch failed me a couple of times. It went out of gear, but not back in to any gear. Leaving it in free, releasing the clutch and then reapplying pressure worked most times.
Today, the clutch failed again. This time the clutch pedal had no pressure at all. Luckily in my driveway, so I walked to work.
Now, after some searching I found this: viewtopic.php?f=8&t=2403 and some external sources telling that the slave and/or master clutch cylinder or seals may be gone.
To fix this, I am planning to take it to Mazda over in Midleton(not the best mechanic myself). To make it over there, should I just fill up with clutch fluid? It is a 30 minute drive to get there. I take since the pressure is all gone, the fluid is probably one under the minimum and the cylinders may have started to corrode due to the exposure of air. Any advise?
