Adjustable cam ???
Re: Adjustable cam ???
Postby charged_rs » Sun, 18 Mar 2012 10:47 +0000
Doc mx5 wrote:Ok.so wats this mean.is it fu***d.should i get rid of it.is there anyone around the dublin area that could have a look at it.or how do i check the timing
it means its not the best..should you get rid of it....yes,i would try and get a standard one from a breakers yard.
all you need is a timing light gun to check your timing dude....reset to the standard 10 deg, however if you get a standard intake cam sprocket you will have to redo your timing belt...not a huge job but then you know your car is fine timing wise.
Thanks for posting the pic ...its scary what some people make to put on their cars, this makes me sad.
Postby Doc mx5 » Sun, 18 Mar 2012 11:13 +0000
Is this safe for the time bein?.so what wil i have get in the breakers.wil i need to get a the timing belt kit while im at it or just the cams.thanks for the replys
Doc mx5
Postby charged_rs » Sun, 18 Mar 2012 11:18 +0000
Doc mx5 wrote:Is this safe for the time bein?.so what wil i have get in the breakers.wil i need to get a the timing belt kit while im at it or just the cams.thanks for the replys
it would be fair to say noone knows if its safe until you get a timing light onto it to see whats happening
You need the intake camshaft sprocket.
When you fit it you might aswell do a timing belt and waterpump but if it has been done recently , dont bother , just refit the belt and reset the timing
Postby Doc mx5 » Sun, 18 Mar 2012 11:20 +0000
sidewaysreilly wrote:Yeah, a very crude Vernier Pulley without the Vernier marks.
what marks are on a vernier pully.thanks
Doc mx5
Postby Doc mx5 » Sun, 18 Mar 2012 11:23 +0000
what marks are on a vernier pully.and what dagree should the timing be set at.thanks again
Doc mx5
Postby charged_rs » Mon, 19 Mar 2012 12:14 +0000
http://flyinmiata.com/index.php?deptid= ... FMSM%20INT
look at the marks on the toda one sold by flyinmiata... yourtiming should be at 10deg from the factory
Postby Doc mx5 » Mon, 19 Mar 2012 12:24 +0000
Cool.thanks ill try source one for it.do i just need someone that has a timing gun to check it.will thay need to take the rocker off to check it or wat do thay do.
Doc mx5
Postby sidewaysreilly » Mon, 19 Mar 2012 2:25 +0000
I think 10 degrees refers to the ignition timing Paul.
Inlet Cam timing should be 5 degrees BTDC and god knows what its set at with that yoke of a pulley.
I have a couple of pulleys if your near Drogheda.
Do get it off tho as you dont know the timing figures and the seller should have explained if the cam was advanced or retarded and by how much and what gains it yielded.
Postby charged_rs » Mon, 19 Mar 2012 2:45 +0000
it would be interesting to know how the car idles and how it drives at low rpm , then how it does on the motorway top end
im guessing it will idle very poorly or very very hard on petrol, possibly both
once replaced , change your spark plugs too
Postby Doc mx5 » Mon, 19 Mar 2012 10:56 +0000
Ok.can i get someone to check the timing.im in the dublin area.if i cant find one up this way ill get on to u.cheers for that.the car is idlen fine.it ticks over at about 900rpm.it ok on petrol.b4 this i had a 02 golf gti 1.8t and its a little bit better than that on fuel.its drivin fine at low rpm and does the clock on motorway.so as far as i can c it drives grand.can i get someone to check it with a timing gun.so should it b at 5deg
thanks
Doc mx5
Postby sidewaysreilly » Mon, 19 Mar 2012 12:37 +0000
Yes but the timing light will show you where your ignition timing is set at. Standard is 10 deg btdc but most people set it at 14 deg btdc for better low end response and pick up. A timing light will not show the cam timing setting but if its idling ok dont worry too much . I would still get rid of that pulley as it looks home made and of questionable quality.
Postby Doc mx5 » Mon, 19 Mar 2012 2:31 +0000
cool,cheers for that.ill get the ign timing checked.what price are u looking for the orignal one,thanks
Doc mx5
Postby sidewaysreilly » Mon, 19 Mar 2012 5:55 +0000
worth a tenner.
Postby Doc mx5 » Mon, 19 Mar 2012 6:11 +0000
Cool.cheers man.it wud cost me more to get down an back.if i dont get one up this way ill get back on to u.
Thanks for all the help
Doc mx5
