My Mini charged 5
My Mini charged 5
Postby andrew » Sat, 14 Apr 2012 9:05 +0000
Hi,
Here is a few pics of mini charger install.
andrew
Re: My Mini charged 5
Postby andrew » Sat, 14 Apr 2012 9:13 +0000
more of the charger
andrew
Postby andrew » Sat, 14 Apr 2012 9:15 +0000
Wideband was installed before the install, to see how the OEM ecu was fueling it n/a
andrew
Postby andrew » Sat, 14 Apr 2012 9:18 +0000
Intercooler went in next
andrew
Postby andrew » Sat, 14 Apr 2012 9:25 +0000
Next was the megasquirt 2 ECU. I had to do some wiring mods to the injector loom as the ECU has sequential injection (smoother idle and better economy) and stock is batch. This was easy enough, I had a local garage do the mechanical work (Leixlip, between Lidl and Intel) so they took out the injector loom and I brought it home modded it and gave it back to the mechanic (Airdidas and Jederus who I highly recommend) to put back in with the 265cc injectors. I had some expected trouble starting it and idling but eventually found a good map on miataturbo and it ran. I was very happy that night.
andrew
Postby andrew » Sat, 14 Apr 2012 9:30 +0000
Then I set the timing using a timing light and the megasquirt software which at first is very confusing to someone who knew nothing about it but after a lo of interweb reading it turns out its very good. It just has so many features that it gets confusing.
andrew
Postby andrew » Sat, 14 Apr 2012 9:49 +0000
So with the car running and idling (very high) it was time to try it out and start tuning the fuel. The megasquirt has a live autotune feature for the fuel. I tried this at idle speeds and it worked very well bring the AFR at idle from 10.2 to the 14.7 target I set it to. It measures the fuel in the exhause at a given rpm and load and changes the fuel value until the target is reached. So out on the road I went and I seen some mad figures on the wideband for the first few minutes but then it started to hit its targets. I did this below 100kpa even though I had a boosted map on the ECU just in case. I then went gently into boost and it felt good. However I was worried about detonation so booked it for mapping with Joe Power from chippedire. He put it on the rollers and hooked up his det headphones to a sensor on the block. Sure enough there was some knock going on that was not audible normal ears so the spark map was changed to very conservative (my choice) as I wanted it reliability more than big power. Then he gradually drove it harder on the dyno as he was mapping it. I was s*****g it woulod break. The noise was unreal even with ear muffs. I was hoping for 160bhp which would be a big improvement on 115bhp (same dyno). Briefly my spec is mini cooper S charger (teflon blades) 17% reduction pulley, front mount intercooler which is very efficient, MS2 with sequential injection, dual throttle bodies for fast response, full stainless exhaust and decat and 265cc injectors. I was very happy with the results I got especially as the boost was very low. I think I had a boost leak - since fixed and the injectors were over 100% Duty cycle at 6000 rpm.
andrew
Postby andrew » Sat, 14 Apr 2012 10:04 +0000
Since this I have splashed out on 550cc EV14 injectors as the 265cc were way too high on DC to be reliable. I have sorted the idle by finging a vac leak when installing the new injectors. They are a bit noisey and I had to retune the fuel table again but the DC is now 45% max, much safer. I still need to find out why it doesn't pull well over 6k rpms. If I can sort that I reckon there is another 10-15 bhp, but I want the revs more than the power.
So next it was off to Mondello on the 30th March for the Octane trackday. It was a different car! with crap tyres it was about 10 secs a lap quicker than before. It was reving much lower than before and I was using a higher gear in a lot of corners and still pulling out of corners quicker. The diff was getting a right workout too. Here a little video of the day, it is still a very controllable car when the back goes out and it goes out a lot on 185/60 tyres. throttle response is 90% as good as it was n/a. This was very important to me as its one of the cars best features and the reason I didn't go turbo. Besides nearly everthing is turbo these days!
http://vimeo.com/39791458
Now I just need some sticky trackday tyres to start chasing elises!
andrew
Postby leamyj » Sun, 15 Apr 2012 9:52 +0000
VERY impressive, just wish I knew what all that data means :?
I'd love to have the time, knowledge AND money to explore the potential of the mx5,
but the lack of all three means I'll stay standard for a long time yet!!
Well done.
Postby andrew » Wed, 25 Apr 2012 3:29 +0000
A little upate, I found out why it wasn't pulling past 6000 rpm. The belt was slipping ! It now pulls all the way to the redline and megalogviewer shows boost increasing all the way there too. Its a lot quicker too after a bit more tuning of the fule table above 6k. I have also just ordered some Federal 595 rs-r tyres for the next trackday. I just need to re install the undertray and duct more air to the radiator to improve the cooling.
andrew
Postby andrew » Wed, 01 May 2013 4:50 +0000
I haven't updated this for a while, but since the last post I've done about 6 track day and had a blast at every one. The Federal tyres made a big difference as the T1R's were getting shredded in half a dry day. They are ok in the wet too.
I think I was doing about 2.20 around the international track when it was standard. I've done a good few 2.05's now and it was keeping up with a Elise 111S (160bhp) until recently as the driver seems to have got the hang of it.
I had a few sessions on track when the water temp tipped over 100 but reduced quickly as soon as I backed off. I am still using the stock rad. i think this is due to the intercooler reducing airflow to a overwork rad. To combat this I filled all the gaps around the rad with expandable foam. trimmed it back and sprayed it silver to hide it a bit. It worked out well, but I haven't done a really hot track day yet.
I took a passenger spin with a well know racing driver from Mondello, who demonstrated there are a couple of more secs to come off the laptime yet. He was driving it a bit harder than I usually do and this showed the clutch was slipping. Not surprising as its a standard 1.6. A new Stage 3 paddle clutch went in recently as did a coolant reroute as it was running a bit hot on track after a few hard laps. I also installed a oil temp guage before the last trackday. Oil never went over 100 Deg C, so no need for a oil cooler.
Next track day is on the 10th May, there will be two supercharged cars on track. My one is the loud one - its hard not to know its charged. The other red one is more descrete. Looking forward to it now.
andrew
Postby andrew » Wed, 01 May 2013 4:52 +0000
How do I resize my pics? or can some do it for me?
andrew
Postby magic » Thu, 02 May 2013 1:07 +0000
Try to re size them before posting. Simplest way use "paint" for it.
... no risk, no fun... :)
magic
Postby Steve » Thu, 02 May 2013 12:19 +0000
^ what magic said ;-)
here they are resized :
Postby andrew » Sun, 05 May 2013 7:27 +0000
Thanks for that Steve,
In preparation for the next trackday I did a coolant reroute and installed a new Stage 3 clutch. Its a paddle clutch, feels like a stock pedal but there is quite a bit of judder moving off from a standstill. Its a bit of a pain driving in traffic but hopefully it will be good on track.
andrew
Return to Turbo Talk
