99 TDI passat
99 TDI passat
Postby mx5ideways » Sun, 20 May 2012 12:56 +0000
I got a 99 TDI passat off my cousin a few months ago and havent driven it yet, it had failed the nct on a suspension arm in the front, it's with a local mechanic at the moment getting new suspension arms in the front, new brake pads and disks and a service, I was going to use it as a cheap runaround but that means I'd have to park up the rs cause I cant insure the both of them at the same time and I don't want to park up the rs for too long! It's too much fun :roll: I'd sell it with everything done for 1000 or would take a swap for a diesel van (I can insure that on a separate policy to the rs at the same time), should have it back next week, give me a call if you want 0874151903, I'm in cork by the way
(il get some pics up soon)
mx5ideways
Re: 99 TDI passat
Postby mx5ideways » Sun, 20 May 2012 9:32 +0000
mx5ideways
Re: 99 TDI passat
Postby haydn itr » Thu, 24 May 2012 12:43 +0000
would u be interested in a seat inca 97 or 99 cant remeber driving perfect but clutch is starting to slip its red clean enough for the year lil cash ur way
haydn itr
Re: 99 TDI passat
Postby mx5ideways » Sun, 27 May 2012 10:04 +0000
haydn itr wrote:would u be interested in a seat inca 97 or 99 cant remeber driving perfect but clutch is starting to slip its red clean enough for the year lil cash ur way
Hi Haydn, just saw this now, any pics? Where abouts is the van? Is it doe'd?
mx5ideways
Re: 99 TDI passat
Postby mx5ideways » Wed, 06 Jun 2012 11:05 +0000
Bump, price drop €900
mx5ideways
