universal joint failure
Postby ger » Tue, 24 Jul 2012 12:20 +0000
Anyone had a UV Joint on the the drive shaft go?
I'm getting a squealing on engine braking and load and reverse, clicks sometimes also on acceleration, which has a similar sound to detonation but is definitely from the rear.
no bad diff whine, half shafts seem good and boots intact, no brake problems or rear wheel bearing issues.
Re: universal joint failure
Postby leamyj » Tue, 24 Jul 2012 1:19 +0000
Happened to me, but I had spare shaft, just swapped it over..no problems since
Postby ger » Tue, 24 Jul 2012 1:46 +0000
Same symptoms john?
Anyone got a spare drive shaft for a 1.6 NA 1990 in the wicklow/dublin area
Postby leamyj » Wed, 25 Jul 2012 1:02 +0000
ger wrote:Same symptoms john?
Yeah,kinda, I had a definite "squeak" at a particular point in the rotation of the shaft, my mechanic diagnosed it as a drying out of a particular part of the UV ( he did use some term which escapes me now), only solution was to replace the UV or the whole shaft as a single unit..I'll bet that Robert in swords will have shafts..do you have contact for him??
We could swap mine onto yours as a means to determine if that's all the problem is??
Postby ger » Wed, 25 Jul 2012 2:21 +0000
Thanks john, It seems like the the uv joint to me, but as i am recovering from a broken rib pulling the shaft to check would be quite painful, also on the idea of swapping over the shafts i appreciate it but it would cost too much in gear oil unless there is a way to stop the gearbox oil spewing out once the shaft is removed.
Postby MX5Spares » Wed, 25 Jul 2012 4:00 +0000
yes we have shaft in swords call 086 8226506 .
Postby leamyj » Wed, 25 Jul 2012 6:38 +0000
ger wrote:Thanks john, It seems like the the uv joint to me, but as i am recovering from a broken rib pulling the shaft to check would be quite painful, also on the idea of swapping over the shafts i appreciate it but it would cost too much in gear oil unless there is a way to stop the gearbox oil spewing out once the shaft is removed.
Hmm, there must be because as far as I know there was no spillage from the gearbox when mine was swapped over. I assume the seal is independent from the splined shaft??
Postby back_in_black » Wed, 25 Jul 2012 7:37 +0000
The spine goes through the seal. If everything is level you'll get some oil leaking when you take the shaft out.
On this one my drive shaft is out at the moment. I was moving the universal joints around and there's a slight click on the diff end when you move it around.
Do you think this is in trouble or on the way out?
back_in_black
