Looks Great!
I was thinking of doing an "MX-5" perforation but we agreed it'd just be tacky.
Re: Mk1 Stainless steel GrilleLooks Great!
Re: Mk1 Stainless steel GrilleHi Geese,
I got my grille the other day and fitted it shortly after. Looks good and it was a good tight fit, had to bend it (bow it) to squeeze past the two tow points. In my case, rather than use cableties, I lined it up with the two 10mm bolts at bottom of radiator mountings, marked them up, drilled two bigger holes and re-installed with stainless steel bolts. A more secure fitting. I might fit the rubber surround at a later date. MaXimu5
Re: Mk1 Stainless steel GrilleMaximus.
Yep that's the way we installed it on our project car. Any pictures?
Re: Mk1 Stainless steel Grillehaving a bit of trouble fitting mine in, not to sure about where to fit it in exactly and kinda afraid of bending it permenantly
Re: Mk1 Stainless steel GrilleOriginal Mk1 bumper? You can bend it slightly it should bend back to shape once in the mouth.
Re: Mk1 Stainless steel GrilleI might have a home for a few if the quality is good and the price is ok
Re: Mk1 Stainless steel GrilleI will take 5 if that helps you but just confirm price is around 30e ??
Re: Mk1 Stainless steel GrilleHi guys sorry been away for a while now.
Is there still interest in the grilles? I've moved on from my old workplace where i made them but I still have a few contacts. Let me know if there's still interest and I'll ring my buddies up. Kaman
Mk1 Stainless steel Grille1 for me for sure
Sent from my iPhone using Tapatalk Mazda Eunos Roadster B2 Limited
Re: Mk1 Stainless steel GrilleIs there anyone else either looking or the Mk1 grille or slam panel?
Please put your name down so I have an idea of the numbers. On friday I shall make a few call and see how much i can get them made for. And of course when I can get them. Hopefully i will have answer for everyone by next mon/tues. Kaman
Re: Mk1 Stainless steel Grilleyea interested as well if your getting some made up.
Re: Mk1 Stainless steel Grilleany of these still going?
Who is onlineUsers browsing this forum: No registered users and 11 guests | ||
