It's finally back :)Picked up my turbo mk1 from trackday performance last thurs and I've finally got a taste of how much fun a turbo'd mx5 is, delighted with it, it's a lot less bhp than I thought it would be, it cost me a lot more than I had hoped and it still needs tidying and abit of work to finish it but fu
![]() ![]() 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
Re: It's finally back :)![]() ![]() I know pictures aren't great but hopefully you can make them out, was told that my exhaust was very restrictive plus I won't get much more bhp with the GReddy emanage but if I change both of them the down line il surely get closer to the 200bhp mark, delighted with the power for now though 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
Re: It's finally back :)excellent! Can't wait to see it!
So you are using the emanage, anything else?
![]() Re: It's finally back :)Great that you have the car back. I'll dig out some of the bits you need to finish the tidy up. Think I have everything except the headlight converters. It'll give you excuse to take a spin over the mountain! I'll text you my number.
![]() Re: It's finally back :)Thanks lads, it's just the emanage on its own steve, theirs different injectors used then your old ones (not sure the size though), the ARTech downpipe and intercooler
Re: It's finally back :)Class. Did they say why there is a droop at 4000rpm? Just wondering ...........
No he diddnt, it was after the garage was closed when I was collecting it so didn't want to hold them up too long, it's not that noticeable driving it though, he just said the exhaust is very restrictive (3" downpipe going to a small 2 and half inch section and then a full 2" exhaust with lots of bends), I might try and get a nice free flowing 2 and a half inch exhaust when I can afford it or see if my brother can make up a 3" one, I think 2 and a half inch will be plenty though cause I'm really happy with how it's driving now, don't think il need much more power, he said a new exhaust could probably get me an extra 20 or 30 bhp, he said get a better ecu down the line too and it would help a lot 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
Re: It's finally back :)Well done, that was a long time in the making. Thats a big dip you have at 3.5 to 4.5k. I'm surprised you can't feel it. I wouldn't bother changing the exhaust and ECU to get from 189 to 200 ish bhp. You got a good torque figure which is main advantage of a turbo. Hope to see it on track soon.
Re: It's finally back :)I think that dyno is way 'off', it's more like 180ish BHP down at the wheels.
Here it is
![]() Re: It's finally back :)Cool! like the dash..which gauge shows the flux capacitor recoil impedance then???
![]() John
![]() Re: It's finally back :)heheh that revs needle is flying round at 4:24.
Thanks Andrew, ya tell me about it! It's my heart broke between the money its costing me and the time it's taken and it's still not right, its not starting a lot of the time ![]() ![]() 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
Re: It's finally back :)I'll be over this evening to take a look, it may be best not to drive it at all until it's sorted out.
![]() Re: It's finally back :)Ok just a few things we found today...
Cam cover is leaking a lot of oil onto the exhaust manifold, it must be taken off and Silicon needs to be placed in those 6 places. Coolant system needs to be flushed and refilled with a mix of Anti-Freeze/Water. Coolant pipe feeding the Turbo is leaking/cracked and needs to be replaced. Oil return pipe needs to be replaced with a steel braided line. Oil pan should be tapped in the correct location. That connector I found near the CAS at the rear left of the engine is for the O2 Sensor - looks like your running with just the Wideband (which is placed in the wrong location and does effect getting a good tune). The other part of the connector should be over to the left near the rear of the manifold. Can the Emanage run with only the Wideband ? Headlights - center console manual up/down button should be checked, steering wheel stalks wiring should be checked, relay should be checked. All in that order. Fuel pump not priming at 'key on' - wiring pins of the ECU/Emanage will have to be checked, if ok then relay should be checked. Fuel pump IS working using the test harness. Cold Start issue - first fix the oil leak and all the above, no point having it running if it's going to be going up in flames again ![]() (edit) I'd think about bringing it back to whoever did the 'job' on it, but since they've messed it up so much maybe it's better not to let them near it again.
![]() Re: It's finally back :)Thanks a million fergus, ya need to get all them bits sorted now as soon as possible, only thing is I'm so broke after it, hardly have a cent to my name, I don't suppose anyone would be up for helping me get the few bits sorted on it? could make a kind of a tech day out of it (some turbo heads or anyone wanting to go turbo might be interested) il try and get what I need over the next week or two and hopefully sort it, I've no car on the road at the moment but I can walk to work from where I am (it's not ideal but it's safer then wrecking the car after all the money I've put into it). I don't want to give it to any more garages, sick of dealing with them, we'll try and get it sorted ourselves hopefully anyway.
