timing advance
Postby james » Wed, 12 Sep 2012 11:54 +0000
anyone done this to a mk2 1.6 ??
14 degrees
james
Re: timing advance
Postby ger » Thu, 08 Nov 2012 11:40 +0000
dont think you can. mk 1 only as far as i remember
Re: timing advance
Postby james » Fri, 09 Nov 2012 12:33 +0000
Your correct the timing is controlled by the ecu on the mk2 and so on
so its always at its best
james
Re: timing advance
Postby charged_rs » Fri, 09 Nov 2012 12:49 +0000
advancing the timing can be done on a mark 2 quite easily
Re: timing advance
Postby ger » Fri, 09 Nov 2012 11:58 +0000
charged_rs wrote:advancing the timing can be done on a mark 2 quite easily
No Interest as I have a mk1 but are you going to leave him in suspense?
Re: timing advance
Postby Steve » Sat, 10 Nov 2012 2:03 +0000
A quick google says you could do this.... (see bottom of the page):
http://www.miata.net/garage/ignition.html#Advancing
or just this :
http://5xracing.com/i-6330020-5x-racing ... ta-v2.html
Re: timing advance
Postby ger » Thu, 15 Nov 2012 11:38 +0000
neither of these seem easy, whats the easy fix charged_rs?
Re: timing advance
Postby Steve » Fri, 16 Nov 2012 1:18 +0000
I think he might be referring to modifying the CPS bracket. Maybe read the first link again, its pretty simple, you are just elongating a bolt hole to move the sensor upwards a little.
Return to Engine Mods
