1.6 vs 1.8 diff casing
Postby rhysmate » Thu, 15 Nov 2012 10:01 +0000
Bit of a strange Q but are the early 90's 1.6 and 1.8 diff casings the same size? my 3'' exhaust runs close to the 1.6 diff and im worried ill have trouble with clearance after fitting the 1.8.
rhysmate
Re: 1.6 vs 1.8 diff casing
Postby Steve » Thu, 15 Nov 2012 12:01 +0000
no, the 1.8 is a bit bigger.
Heres a photo I took a while back :
More photos + info here :
http://www.miata.net/garage/diffguide/index.html
Postby rhysmate » Thu, 15 Nov 2012 2:49 +0000
its definitely longer but is it wider? cheers man ill take a look
rhysmate
Postby Steve » Thu, 15 Nov 2012 5:52 +0000
as far as I remember the axles on the 1.8 are a little shorter so.. yeah wider
Postby MX5Spares » Thu, 15 Nov 2012 7:15 +0000
I think both are same width ,but I could measure a 1.8 for you.Definitely 1.8 is longer and a shorter diveshaft also. We have both types if you do need anything.Robert 086 8226506
Postby rhysmate » Sat, 17 Nov 2012 11:58 +0000
Thanks rob. I have both and all shafts from a donor :-)
rhysmate
Postby MX5Spares » Sun, 18 Nov 2012 8:17 +0000
Straight swop -
Return to Engine Mods
