I've had my car supercharged and running a megasquirt with 550cc injectors for nearly a year now and its been great on track and on the road. I had been a bit worried about the NCT as the idle speed was inconsistant and when it drops below 800rpm it ran a bit rich (13.0 - 14.5) anything above that and it was nice and steady around 14.7 +-0.3. Funnily enough I got a steadier reading by disabling EGO correction and just using the fuel table.
So, into the test center this morning with the laptop in the car, I asked the receptionist if I could watch the idle test (car is 93, no cat) and adjust if necessary. I was fully expecting a Health and Safety answer, but suprisingly she said 'no problem they are just going to bring it in now' I told the tester about the ECU and he said 'what is it a 93? sure there will be no problem'. I watched the AFR while he was testing it and the wideband read 15 ish. 'Yeah', he said 'no problem'. Relieved I went to watch the rest of the test upstairs, half expecting it to fail on something else (e.g. quick release steering wheel) as I hadn't checked anything else beside fluid levels.
20 mins later, a fresh NCT cert was issued. Happy days !!
