Mx5/Eunos specific NCt problems
Postby fez » Mon, 11 Feb 2013 5:10 +0000
Have my NCT in 2 weeks, is there anything specific to the mx5 or eunos(particualrly since its a jap import) that I should look out for? Made sure my number plates are legal and put two new tyres on it at the weekend. will probably need new rear pads too, I noticed as the wheels were off. Should the handbrake strength increase with new pads?
fez
Re: Mx5/Eunos specific NCt problems
Postby MX5Spares » Mon, 11 Feb 2013 5:49 +0000
New pads wont actually help the handbrake unless old pads are metal to metal( fully worn out) but calipers need to be freed out sometimes and most important to grease the slider pins on which the calipers move as these seize regularily.If you want you can ring me.Really easier to go for NCT and just repair what actually needs to be done.Also top up fluids ie brake fliud,washer bottle etc and if you have RED side marker lens in bumpers you need to cover them temporarily with black tape/This is recommended by NCTS company.Amber side lens are ok.Remove hub caps if fitted as wheel nuts need to be visible.Other than that take your chances !!! Robert
9
Postby sidewaysreilly » Mon, 11 Feb 2013 6:24 +0000
get a 10mm socket on a rachet and pull up the adjuster beside the handbrake when you are outside the test centre and ease it off when your done.
Postby rhysmate » Tue, 12 Feb 2013 12:37 +0000
Do what robert said. No sense in trying to scrape through an nct, put it through and fix what needs fixing
rhysmate
Postby fez » Tue, 12 Feb 2013 4:05 +0000
Cheers lads, was just issues like the indicator lenses I was worried about. mine are orange thankfully. In order to adjust the handbrake is it the wee hole on the passenger side plastic?
fez
Postby sidewaysreilly » Thu, 14 Feb 2013 11:00 +0000
no its a nut standing up to the right of the lever as you look down. Pull the boot up first and you will see it.
Postby fez » Fri, 15 Feb 2013 9:24 +0000
Looked for it there earlier, couldn't see it. There's no boot on the handbrake, will have a proper look in the morning.
fez
Postby leamyj » Sat, 16 Feb 2013 8:03 +0000
If not a boot, plastic moulding??
Postby fez » Mon, 18 Feb 2013 1:03 +0000
yep, took off the plastic and found it, much better now.
fez
Postby fez » Tue, 19 Feb 2013 5:48 +0000
1 hopefully last question. Can you fail on worn pedal rubbers if you don't have pedals with rubber on them? Mine are just metal with grippy bits.
fez
Postby leamyj » Tue, 19 Feb 2013 7:24 +0000
That will probably depend on the individual tester..it would only be a matter of re-presenting the car for a visual if that's all he gets you on.
John.
Postby fez » Wed, 20 Feb 2013 1:22 +0000
cheers!
fez
Postby Steve » Wed, 20 Feb 2013 6:14 +0000
Mine have none and failed on it until I pointed out p16 in the manual
"Brake pedals should not be rejected for not having a pedal rubber if they were not designed to have one."
Postby fez » Thu, 21 Feb 2013 11:16 +0000
Steve wrote:Mine have none and failed on it until I pointed out p16 in the manual
you sir are a well of knowledge.
fez
Postby fez » Mon, 25 Feb 2013 3:35 +0000
Failed on rear brake pads so I'm counting myself lucky that I wasn't told it was falling apart.
fez
