engine flat spots,then goes!
Re: engine flat spots,then goes!
Postby rhysmate » Tue, 19 Mar 2013 2:18 +0000
CAS is the Cam Angle Sensor. works kinda like a distributor. But it is more than likely your fuel filter. Let us know Man!
rhysmate
Postby stag76 » Tue, 19 Mar 2013 7:29 +0000
hi rhysmate,got your message,ah thats what that means.
im into bmw also,and its known as a crank shaft position sensor in the bavaria :D
filter ordered,so cant wait myself :D
keep you all posted on this 1.
jay
stag76
Postby pjmazda » Tue, 19 Mar 2013 9:44 +0000
Hi jay,
I cleaned my injectors with carb cleaner, spray can from motor factors, but I suppose I could have just used petrol.
P.j.
pjmazda
Postby sidewaysreilly » Wed, 20 Mar 2013 1:51 +0000
oh god........
Postby stag76 » Wed, 20 Mar 2013 3:51 +0000
hi lads,have spent the last few hours on the mx5.
changed filter,took pump out,cleaned filter bag mesh. drained out tank,bit of sediment both on pump and in tank,but not enough to reduce flow.
checked pump fuel delivery in engine bay useing the diaginostics plug,good pressure and it shot a good distance.
cheched plugs,all good,and a good colour.
looked at all the earthing cables,good and tight. inspected fuel lines underneith,all good no damage,or pipes flattened.
have just gone for a drive with petrol cap loose and a mix of 10euro of petrol and a can of injection cleaner.
started engine,again a bit of turning over and peddle pumping,down the road,what do you think??
the bloody same :shock: :shock:
anybody want cheap mx5 :lol:
thanks jay
stag76
Postby charged_rs » Wed, 20 Mar 2013 4:02 +0000
did you check your cas?
could also be your coilpack!
Postby Steve » Wed, 20 Mar 2013 4:09 +0000
give the wires behind the intake manifold a wiggle with the engine running too while you are in there
Postby pjmazda » Wed, 20 Mar 2013 7:44 +0000
The only thing left in fuel delivery is injectors, start engine, long handle screwdriver on back of each injector and listen for constant click. If no click or irregular its hosed....
pjmazda
Postby pjmazda » Wed, 20 Mar 2013 7:46 +0000
http://www.youtube.com/watch?v=7aT4S1lI ... ata_player
This is what I followed, went like a rocket afterwards...
pjmazda
Postby stag76 » Wed, 20 Mar 2013 11:23 +0000
hi lads,no hair left,ive pulled it all out.
how do i test the cas??
i changed over coil pack there this after noon,no change
the car runs on 4cyl always,so dont think its injectors.
when i drive it and go around a corner it will splutter and die,it will restart then and drive again :o
go around a roundabout and a quarter the way round your buggered,scary to :shock:
its a physical thing,its fuel,not ignition,its a fuel thing.
il just have to try a pump and see what happens,il be onto robert for a few loan items to test with.
thanks for all the input
thanks jay :wink:
stag76
Postby sidewaysreilly » Thu, 21 Mar 2013 7:48 +0000
Check there are no cables frayed and earthing out on the body. Could be anywhere from the battery forward. Get someone to rev the car say 3000 rpm in neutral and wiggle all the wiring, bit by bit, circuit by circuit. Check all deutsch plugs on engine loom. Pins can corrode, dislodge. Its probably wiring somewhere.
Postby pjmazda » Thu, 21 Mar 2013 7:55 +0000
Post short video of running issues might help jog some suggestions.....
pjmazda
Postby charged_rs » Thu, 21 Mar 2013 8:34 +0000
if you are swapping parts out and borrowing parts to test , how do you know the one you are borrowing is working ?
there are only a few things that would cause this
coilpack - ht leads
cas - if the car is hard to start its a sign its not too healthy
AFM
possibly the fuel rail regulator
whats the timing currently set at ?
if you have checked all those and still have the problem , break it for parts.
Postby pjmazda » Thu, 21 Mar 2013 8:53 +0000
Actually get 12v led from radionics and run OBD1 testing .... procedure well documented on web .... might also be worth a try....
pjmazda
Postby charged_rs » Thu, 21 Mar 2013 8:58 +0000
pjmazda wrote:Actually get 12v led from radionics and run OBD1 testing .... procedure well documented on web .... might also be worth a try....
http://www.miata.net/garage/Engine_Diagnostics.html
