Fitted new vinyl top over the weekend. The rain rail needed plenty of attention because the last roof used nuts and bolts in the old pop rivet holes and made them bigger. Anyway loads of 007 and tape later it all looked good. Fitted the roof and torqued the nuts of the rain rail in proper order.
When doing the water test it leaks in the same place on both sides. Its on the left and right of the rear window. If I take it essy on the water it works fine. If it pools it looks like the water comes down the back of the rail.
Any ideas??
I've had the rail out again and redone the fitting twice same issue. Close to just putting the hard top back on!
HELP!!!
