by Jellybean » Tue, 06 Aug 2013 11:30 +0000
Latest updates, spend about 8 hrs on her yesterday
The little MX has electrical problems!
You could say the MX5 has 2 engine looms , one half of the loom is attached to the Dash and the other to the firewall, to make things easier for us we disconnected the loom from the Dash and took the dash out of there so we could trace and diagnose issues a lot easier.
The only items not connected are the two footwell lights (either side of the centre console) and cigarette lighter (all three are integrated to the dash) but these will not cause the car not to start.
Issues
Early morning Scenario
· The fuel pump was priming and we had dash lights, looks light an earth was disconnected over in the passenger dash area
· no spark
· Could not find any continuity within the harness between the ignition coil loom pins and the corresponding ECU loom pins ( forget the wire colors but I can get them)
· No relay clicking
· No revs on the tacho when trying to crank her
Current Scenario
· In order to trace the wires for the ignition coil we removed the dash and harness from the dash, reconnected everything minus two footwell lights (either side of the centre console) and cigarette lighter
· Now we have no dash lights, Charge, Brake .. but it will show the symbol if we turn on the headlights, indicators
· No fuel pump working
Any advice, we are thinking a relay is gone, fuses are all fine , inside and out plus all grounds are triple checked.
