Re: diff identity by number on crown wheel 1245Did you try count the teeth on the crown wheel and pinion?
![]() Re: diff identity by number on crown wheel 1245Not yet but is it as simple as counting the teeth on the crown wheel per revolution ???
Re: diff identity by number on crown wheel 1245Are you wanting the diff ratio?? Count teeth on the crown wheel and then count teeth on pinion and divide first number by second
![]() Re: diff identity by number on crown wheel 1245I knew it was something like that but thanks that's easy .!!
Re: diff identity by number on crown wheel 1245Dead easy, turn the input flange and count how many revolution it takes to rotate the output /shaft side one revolution.
