altenator belt squealing when engine cold
Postby jumpinac » Wed, 02 Apr 2014 8:23 +0000
have replaced it twice in 9000 miles still squealing ,waterpump and timing belt done the second time i replace other belt any ideas why its squealing
jumpinac
Re: altenator belt squealing when engine cold
Postby Fergus » Wed, 02 Apr 2014 9:45 +0000
It probably just needs to be tightened up a bit.
Postby jumpinac » Wed, 02 Apr 2014 11:58 +0000
when i have u ,when reving her hard above 6.5k the lights dim,whats that likely to be
jumpinac
Postby Fergus » Wed, 02 Apr 2014 12:52 +0000
If you have put in a new alternator belt, after a while it would need to be tightened up after it beds in.
If it's slipping then your battery will start to go flat, lights dimming etc.
Postby jumpinac » Wed, 02 Apr 2014 1:06 +0000
all realated so thanks fergus as usual great help
jumpinac
Postby Fergus » Wed, 02 Apr 2014 11:32 +0000
Don't tighten it up to much though or it will wear out faster.
The middle of the belt should have a 'deflection' (distance measured when you push the belt up and then down - it's the gap measured inbetween).
1989 - 1993 = 8.89mm to 9.90mm
1994 - later = 6.09mm to 7.36mm
Hope that helps ;)
Postby jumpinac » Thu, 03 Apr 2014 11:11 +0000
huge help thanks very much
jumpinac
