MK1 eunos gear nob thread size
Postby emmet.harten3 » Fri, 30 May 2014 11:58 +0000
i wonder what size MK1 eunos gear nob thread size is??? the size on the shaft that the knob screws on to..... is it m10 X 1.5 or m12 x 1.25??
i have a wooden nardi gear knob and it 22 years old it well worn but the knob has come away from the insert to i cant take it off it just spinning around
so i want to get a new 1 a after market 1
emmet.harten3
Re: MK1 eunos gear nob thread size
Postby davith501 » Sat, 31 May 2014 6:56 +0000
The insert is glued to the knob it became loose so it spins. Give a good pull should come off and then you'll you'll be able to tackle the insert.
Deivis
Icon
RS
Mk1
davith501
Postby emmet.harten3 » Sat, 31 May 2014 10:29 +0000
i tryed pulling it there its stuck and i seen hole in gear stick looks like a screw was there but it removed so dont no what hole is on
emmet.harten3
Postby davith501 » Sat, 31 May 2014 11:19 +0000
emmet.harten3 wrote:i tryed pulling it there its stuck and i seen hole in gear stick looks like a screw was there but it removed so dont no what hole is on
Did you try vice grips? Post a pic for clearer view.
Deivis
Icon
RS
Mk1
davith501
Postby AndyJF » Sun, 01 Jun 2014 9:38 +0000
There is probably a short grub screw in that hole. Use an allen key to remove it.
AndyJF
Postby emmet.harten3 » Sun, 01 Jun 2014 4:51 +0000
she's tight as a nuns knickers still on she gear stick
http://www.servimg.com/image_preview.ph ... u=17940075
emmet.harten3
Postby fez » Sun, 01 Jun 2014 7:59 +0000
Its m10 x 1.25 afaik. Not sure if theres a grub screw as mine has a pool ball on it.
fez
Postby davith501 » Sun, 01 Jun 2014 9:19 +0000
Does the metal part where little screw was spins with the knob or the wooden bit only? Is the screw missing or its stuck deep inside?
Deivis
Icon
RS
Mk1
davith501
Postby emmet.harten3 » Mon, 02 Jun 2014 3:35 +0000
fez wrote:Its m10 x 1.25 afaik. Not sure if theres a grub screw as mine has a pool ball on it.
is it a right hand thread?? i getting custom gear knob made for it and it m12 x 1.25 so i have to get a adapter to fit m10
no it just the wooden bit that spins around... and it squeaks to
emmet.harten3
Postby davith501 » Mon, 02 Jun 2014 8:03 +0000
If you don't care much split it.
Deivis
Icon
RS
Mk1
davith501
Postby emmet.harten3 » Mon, 02 Jun 2014 8:54 +0000
dose the steel bit the the little screw goes into turn screw off??
ya i say i have to
emmet.harten3
