Failed NCT on emission
Postby shan001 » Wed, 04 Jun 2014 2:11 +0000
Hi,
Please help me with this issue on my MX5.
I have a mk1 NA Eunos from 1992.
It has failed emission test on the NCT, and it has failed by a lot
The lambda sensor has been changed on the car. The car does not have steady idle, in particular when egine is cold, it keeps stop running.
My mechanic refers to an Air Fuel Ratio sensor. Is there such a thing in this car, can I buy it from your site if it exists.
What else could cause the problem? Any help welcome, thanks.
shan001
Re: Failed NCT on emission
Postby MX5Spares » Wed, 04 Jun 2014 10:02 +0000
We have loads of mx5 part sin Dublin 086 8226506 but without confirming exactly what is wrong you could be going back to NCT for the next year !! Some have air flow sensors ,some have MAF sensor ?? early and late type and 1.6 or 1.8 but we have them all.
Postby Steve » Fri, 06 Jun 2014 11:11 +0000
Check your air intake pipe post-air flow meter for leaks. Any hissing around the intake manifold? Does it idle ok?
Also, this is worth a read re additives :
viewtopic.php?f=3&t=6382&start=30
Postby ger » Fri, 06 Jun 2014 9:16 +0000
I had similar problems to this turned out to be my o2 sensor and a hole in my exhaust, while trying to locate the problem I did clean the airflow meter and throttle body and intake manifold. One other thing that can cause this is the temp sensor http://www.mx5parts.co.uk/sensor-water- ... p-862.html at the back of the engine or a faulty airflow meter. My nct went from 8.5% CO to 0.37% CO.
Postby shan001 » Sat, 07 Jun 2014 5:48 +0000
Many thanks for the comments, mine is 0.755, so have a lot to do I'd say.
If the weather stays I'll get my hands dirty tomorrow :P
shan001
