Its in good condition no leeks or bad corrosion. Only the usual surface rust that comes off with a wire brush.
Exhaust tip needs a polish but is not damaged or corroded.
€25
MK1 Standard Cat BackSelling my old Cat Back exhaust as I fitted a twin exhaust earlier this year and now have no use for it.
Its in good condition no leeks or bad corrosion. Only the usual surface rust that comes off with a wire brush. Exhaust tip needs a polish but is not damaged or corroded. €25 ![]() ![]() Sent from my GT-I9505 using Tapatalk Last edited by AndyJF on Mon, 20 Oct 2014 10:06 +0000, edited 1 time in total.
Re: MK1 Standard Cat BackWhat bore is it?
...in many ways, I'm a very bad man...
Mk1 1.8 'G-Limited' Jap Roadster
Re: MK1 Standard Cat BackIts the standard factory one. I think there 1.75 inch.
What year is your 5? ...in many ways, I'm a very bad man...
Re: MK1 Standard Cat BackIts a 1994. Should fit all MK1s as far as I know.
