What turbo to choose?
Postby ChocMiata » Mon, 20 Apr 2015 12:33 +0000
I have been told that the 1.6 mx5 engine is the same as the engine in the 1.6 turbo 323. Is this true? With that in mind I have found a manifold and turbo from a 323. Would it work?
ChocMiata
Re: What turbo to choose?
Postby andrew » Mon, 20 Apr 2015 8:30 +0000
yep, but you will need the ecu from the 323 too
andrew
Postby ChocMiata » Fri, 24 Apr 2015 5:05 +0000
What kinda HP increase would I be looking at?
ChocMiata
Postby Steve » Sat, 25 Apr 2015 2:26 +0000
I don't think the manifold will work without some customising... its the wrong orientation. You'd need to cut and reweld it so it points backwards and not out under the engine (323 engine was traverse).
Re the ECU, would that work? I thought they had a distributor no?
Postby ChocMiata » Sat, 25 Apr 2015 7:03 +0000
Yeah I noticed that. Ive located a td04 from a scooby and I'm going to get a wrecked manifold and make up my own one.
ChocMiata
Postby Steve » Sun, 26 Apr 2015 12:25 +0000
nice, sounds like a good project. Post progress pics if you think of it, would be interested to see.
Return to Turbo Talk
