Randy wrote:Do a build thread man in the project section. Would love to see how you get on with it.
just did, the start of the project
Re: Need a map (Jul/Aug 2015)
Re: Need a map (Jul/Aug 2015)Where about are you based?
Here in Cork, would recommend Bart @JDM Garage.. EDIT: If you have a MSPNP Gen2, you can re-wire the injectors to run in sequential mode, as the 850cc/min is quite big for firing them twice per cycle (batch mode) Nico
Re: Need a map (Jul/Aug 2015)Are you hoping to get 400 from the 1.6?
Re: Need a map (Jul/Aug 2015)what turbo?
Re: Need a map (Jul/Aug 2015)A Garrett GT2871R would get there, or perhaps a TD05-20G but would be at its edge.
The 1.6 head doesn't seem to flow that much, would need serious porting and defo aftermarket cams! Nico
