How is your intercooler mounted?
Postby emarkey » Fri, 05 Jun 2015 9:56 +0000
Just got an intercooler off an evo and looking for suggestions how to mount it. There is a little bracket at the top of it where I could hang it off, but thats only 1 point.
would that be enough? do they move much?
emarkey
Re: How is your intercooler mounted?
Postby Steve » Fri, 05 Jun 2015 11:19 +0000
ideally two points, that said, mine is mounted by one point on the top left of the intercooler to one of the bonnet catch holes (AFAIR). Its fairly solid and can't really move once the intercooler pipes are on too.
Postby emarkey » Fri, 05 Jun 2015 11:30 +0000
Cool. I cant imagine it would move too much with pipes on it. The bracket on it is at the top and right in the middle, so surely something bolted very tight to that will hold it nicely. Thinking of making 2 brackets that hang down behind at each end and cup the bottom of the intercool. Might do that job.
emarkey
Postby Piers14 » Fri, 05 Jun 2015 12:21 +0000
Not sure if you are going top mounted, but if it helps, this is how I did it. Two bars connected to right angle brackets.
Piers14
Postby emarkey » Fri, 05 Jun 2015 12:50 +0000
Thanks. I guess I could try something like that.
emarkey
Postby [L'e$kro] » Sun, 28 Jun 2015 3:07 +0000
Threaded bar from the 2 top inserts of the IC, with nuts sandwiching the slam panel.
Nico
[L'e$kro]
Return to Turbo Talk
