Power Steering Fluid use?
Postby gary k » Fri, 25 Sep 2015 9:55 +0000
Since I've started drifting I've noticed that my power steering fluid reservoir always boils over and from what I gather it is a common occurrence in the MX5s after some "spirited" driving. I have been recommended to using the Red Line Power Steering Fluid as it is supposed to be much more durable and heat resistant. Has anyone on here used it or would I be better just getting a power steering fluid cooler or just remove the power steering altogether?
Also, if I were to use the Red Line fluid, does anyone know how much power steering fluid an MX5 takes?
gary k
Re: Power Steering Fluid use?
Postby scallan » Fri, 25 Sep 2015 2:48 +0000
I removed it all together on my track car and im considering doing it with the road car aswel as it boils the odd time but suppose its up to ur own prefrences
scallan
Postby gary k » Fri, 25 Sep 2015 4:17 +0000
Did you find much difference on the track with and without powersteering?
Also did you put in a manual rack or did you just depower your own rack?
gary k
Postby scallan » Fri, 25 Sep 2015 4:38 +0000
Depowered my own rack as manual is a longer rack turn to turn. Eh i found it grand out on track bit of hardship turning at 1mph but once you get going its grand
scallan
Postby gary k » Fri, 25 Sep 2015 8:07 +0000
I read a couple of different ways people depower it, is it a fairly simple job?
gary k
Postby scallan » Fri, 25 Sep 2015 8:33 +0000
I followed miata.net guide i think. Took the rack apart and done it that way. Also you have to weld the pinion which is not in that guide but in some of the others
scallan
Postby gary k » Sat, 26 Sep 2015 11:33 +0000
Must have a look at it, thanks a million!
gary k
Postby sidewaysreilly » Sat, 26 Sep 2015 5:12 +0000
Put a small oil cooler in the pipe. Sorted.
