seized lower wish bone bolts
Postby Real Rayzor » Tue, 19 Jan 2016 1:12 +0000
Hey all.. I'm trying to undo the 2 rear lower wish bone bolts on a mk1. It's the bolt by the hub. They are stuck solid. I have oiled the hell out of them beat the sh*t out of one of them to the point where I've ruined the bolt.. is it a case of just cutting them out. I heard they can be a bast**d.
Real Rayzor
Re: seized lower wish bone bolts
Postby Billium94 » Tue, 19 Jan 2016 2:38 +0000
Have you tried heating them? And for the ruined bolt it's get a vice grips with decent teeth into it to try turn it...then heat and try turn and keep repeating
Billium94
Postby Real Rayzor » Tue, 19 Jan 2016 9:44 +0000
Haven't tried heat.. I don't have a blowtorch thingy. I'll try a heat gun tomorrow.. cheers
Real Rayzor
Postby scallan » Wed, 20 Jan 2016 8:48 +0000
Heatgun wont get hot enough. You can pick up gas powered blowtorches for handy money
scallan
Postby Real Rayzor » Wed, 20 Jan 2016 2:45 +0000
Well lads. Tried it with 2 heat guns today and got it out. The bolt is fubar but I can just replace that. I'll try the same on the other one tomorrow. Jesus I'm wreaked after it.. :D
Real Rayzor
Postby Merlot man » Wed, 20 Jan 2016 7:13 +0000
Hello Ray
I think the biggest problem is that they come through the bottom of the stub axle and are exposed to all the shit from the road , in the past I've cleaned as much of the rust from the exposed portion of the bolt as possible using hammer and chisel , rotating the bolt using a long 600 mm breaker bar( my very BEST friend ) then cleaning more , I would also recommand my old friend worth rust off , great stuff I think . The heat will work but you need a proper blow touch , something like what the Plummer uses and be carful not to melt the bush .
Och the joys of restoration !
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby Real Rayzor » Thu, 21 Jan 2016 9:48 +0000
Thanks for the advise Brian.. I did try scrapping some of that crap off.. I had a go at the second one yesterday but no joy. Gonna give it another go today and smack it with the big heavy hammer.
Real Rayzor
Postby Yolo » Thu, 21 Jan 2016 11:52 +0000
I had the same problem when I was doing my bushes last year it is a pig. lots of regular spraying didn't work hitting it didn't work. An impact driver didn't work. In the end it was a gas powered torch and a 4' scaffolding bar got it out.... for the record new bolts are £15 each from mazda, ask me how I know.....
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby Real Rayzor » Fri, 22 Jan 2016 11:55 +0000
Got the second bugger out... my new motto "hit it with the big hammer" :D
Real Rayzor
Postby Merlot man » Sat, 23 Jan 2016 10:51 +0000
That's great news Ray
Make sure when your refitting the bolt to grease it and pack the exposed portion with grease as well , it helps keep the rust away .....big hammers , I live them !
Brian
93 na s ltd
Merlot man
Postby Real Rayzor » Sat, 23 Jan 2016 11:29 +0000
Will do Brian.. just need to pick up a couple bolts now. :roll: :D that's the thing with big hammers. :D big damage :(
Real Rayzor
Users browsing this forum: Baidu [Spider] and 1 guest
