Mk1 mx5 1.6 air con condenser
Postby Davemx-5 » Mon, 02 Jul 2018 6:35 +0000
Hi all,
My air condenser is badly screwed and way beyond repair.
Mazda says they've discontinued the part.
Anyone else wanting to save their aircon manage to find a solution?
Davemx-5
Re: Mk1 mx5 1.6 air con condenser
Postby Pops » Tue, 03 Jul 2018 12:29 +0000
Give Robert a shout, I’m sure he has what you need
Postby MX5Spares » Mon, 09 Jul 2018 8:12 +0000
We have new one but its for left hand drive mx5 so it needs pipes modified but easily done,.I may also have used ones . 086 8226506
Postby leamyj » Fri, 13 Jul 2018 5:31 +0000
Excuse my ignorance, the condenser ? Is that under the hood or behind the dash?? I removed and since disposed of the under hood parts, but the behind dash stuff is still there..
Postby Steve » Thu, 19 Jul 2018 1:22 +0000
As far as I remember, the condenser is the cylindrical shaped object attached to the Aircon radiator at the front of the engine bay (if you look down at front of radiator you should see a small eyeglass type thing on the top of it). The bit under the dash is the evaporator.
Postby Davemx-5 » Fri, 20 Jul 2018 9:10 +0000
Rob bought a used one off you, arrived during the week cheers. By air con condenser I mean the radiator. Mine has totally disintegrated and the cores just fallen out completely. Going to give this a go sealing them soon. Is it possible to convert these to the new air con gas?
Someone on a merc forum said they can use some sort of oil to allow the new gas in the aircon system but no idea.
Davemx-5
Postby Steve » Sun, 22 Jul 2018 11:45 +0000
Some good info here on the procedure : https://www.miata.net/garage/r134.html :-)
Postby Davemx-5 » Tue, 24 Jul 2018 9:56 +0000
Cheers for that Steve, loads of information there. Kind of goes over my head!ha
Davemx-5
