Re: Thoughts on the new Mk4 NDV
Re: Thoughts on the new Mk4 NDHi Tom, the engine backplate is probably a generic piece that suits various cars so I wouldn’t worry about the empty hole, there may well be a corresponding one on the passenger side that is being used on your car.
You seem to be lacking something that every other model has.......... a rusty underbelly
Re: Thoughts on the new Mk4 NDI put my Summer wheels back on the car today.
Hope I'm not tempting fate, and the snow is actually gone till next winter I also did this-- http://www.mx5ireland.com/forum/viewtopic.php?f=12&t=8739 Tom.
Re: Thoughts on the new Mk4 NDHere is another addition to my ND, prompted by reading threads on the US forum, Miata.net
In case you're wondering. What you are looking at is the line of light between the two tail lights. That strip of LEDs wasn't there until yesterday but I think it looks like it could have come from Japan like this. You do not have the required permissions to view the files attached to this post.
Re: Thoughts on the new Mk4 NDThat looks really good, I like the way it connects both tail lights
Re: Thoughts on the new Mk4 NDNice - looks really well.
Re: Thoughts on the new Mk4 NDwow... love it
Re: Thoughts on the new Mk4 NDThanks guys for the positive comments. I copied the idea from a number of posts on Miata.net in the USA.
Today I added an idea of my own, I fitted a relay operated from an ignition feed, so the feed from the tail-light plug+socket to the LED strip is only live when the ignition is on. So if I have to leave the car with the parking lights on for any length of time, the load on the battery is as Mazda designed it and not 6 watts above. I showed this to my Mazda guy today as I was booking the car in for it's yearly service, and he asked if I thought the cops might object to this change. But when I showed him the night-time photo that shows that it appears to be the same brightness as the original outer loops, he was less concerned. Also some of this years new cars are going this way,- such as the Lexus in the current TV advert.
Re: Thoughts on the new Mk4 NDLast Friday when my car was up on the lift for it's second annual service, the only noticeable
corrosion we seen was on the three aluminium chassis cross-member panels including the one you remove to access the oil filter. This corrosion shows itself as a white floury powder that can be brushed off and when the panel is struck with the back of a wire brush you get a ringing sound so I wondered if these plates might actually be galvanized steel, but a magnet doesn't stick so they must be aluminium. Yesterday I removed these panels brushed off the 'flour' and painted both sides with aluminium zinc aerosol. While I had the front of the car up on axle stands I decided to remove the plastic wheel arch liner and examine the area behind it. It was nice to see that the plastic liner is doing a good job of keeping all the dirt and road-spray out. Since I had the liner off, I got out my can of Hammerite Underbody Seal and sprayed all the grey and red areas black. And the area that had to be often cleaned out on the NA and NB cars You do not have the required permissions to view the files attached to this post.
Re: Thoughts on the new Mk4 NDSounds like a nice bit of preventative work. Anything to keep the Tin worm at bay is always good!
Re: Thoughts on the new Mk4 NDYea. Now I have to get round to getting the rear arches done,- to keep the 50-50
weight distribution correct!
Re: Thoughts on the new Mk4 NDHi all. Here's my latest little addition to my car.
. . These stick-on rings come ready painted to match Mercedes cars. https://www.amazon.co.uk/gp/product/B0776RXDKD/ref=ppx_yo_dt_b_asin_image_o01_s00?ie=UTF8&psc=1 Some of the USA owners on Miata.net had started pulling the vent units out of the dash and dismantling the rings, to paint the inside of the rings, just like Mazda has done with the dashboards of the orange 30AE. Then somebody found these sets on amazon. You do not have the required permissions to view the files attached to this post.
Re: Thoughts on the new Mk4 NDha, brilliant!
Re: Thoughts on the new Mk4 NDOver a week ago I fitted this adaptor cable
https://car-solutions.com/en/car-camera-connection-cable-to-mazda-mzd-connect/?utm_source=marketing&utm_medium=email&utm_campaign=Leave+Feedback&mailhash=dXQjMzQyMTI1MzU%3D to the back of my infotainment unit so that I could view my reversing camera on it's 7 inch screen. I had been using the 4.3 inch flip-up screen that I transferred from my mk2 along with it's camera. The whole operation went perfectly, following online pictures and videos from forums and suppliers of the oem kits, after I did the three button reset of the infotainment CMU. Then I discovered that the CMU would forget the camera if the car was locked and left alone for 3 minutes or more, and I had to reset the CMU again to use the camera. My camera was still powered from the reversing light supply and I found instructions on the car-solutions web site that 12v cameras be supplied directly from the ACC (accessaries) supply. The reason being that the camera had to be powered when the CMU was starting up from sleep mode. So I did this by running another wire back into the boot, but I still had the same problem. The camera and adaptor cable kits that are available have the camera working off a 6 volt supply from the CMU cable. Next I went back and connected two wires to the 6volt supply and brought them down to the passenger footwell. I connected a small 6v relay- at first just to make the CMU think it was powering a camera, still had the same problem. Then I routed the wire feeding the camera through the relay so that the camera would go on and off as the CMU demanded. I still had to do the reset for the picture to display but at least the camera was only on in reverse and not for the whole journey, I could tell by listening to the click of the relay. With a bit more on-line research I discovered that a guy on the UK MX5 owners club forum who sells the best value kit I have come across, uses a 12volt camera and a small step up boost convertor from amazon to change the 6v to 12v. I was about to order one of these but I suddenly had a great idea! I took a 6volt lead acid battery I had bought as Maplins was closing down, and still had 6 volts in it and connected it to my camera (which I had bought as a 12v one) and it worked, it took 84 milliamps On 12volts it takes 85 milliamps Thinking simplistically you would expect a 6v item to use twice the amps of a 12v one to do the same job, but these cameras run at 3.3 volts and have inbuilt circuitry to drop the incoming voltage. https://www.amazon.co.uk/gp/product/B00ZCJI4NE/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 So next job, I run a new power cable (cut from leftover cable from the house security camera update) with the plug already fitted to match the camera power socket, from the boot to the 6v wires through a fuse holder. One more reset and lock the car, check it an hour later, select reverse, screen is live. It's been working perfectly since. You do not have the required permissions to view the files attached to this post.
Re: Thoughts on the new Mk4 NDNice bit of thinking there, reversing cameras are great, I've one in my work car and it also has blind spot monitoring which is brilliant but the drawback is that I've become nearly reliant on the system which doesn't help when driving the other cars, it's probably age catching up but trying to judge the dimensions without the cameras has become nearly impossible
Who is onlineUsers browsing this forum: No registered users and 12 guests | ||
