Re: A German is trying to invade my Japanese territoryI do believe that the missfire count is electrical but I'm trying to rule out the easy stuff first, I've seen a post somewhere about a bad wire going to the coil causing the same problem
Re: A German is trying to invade my Japanese territoryThat wasn't the one that connects under the intake manifold by any chance? Sent from my Redmi Note 5 using Tapatalk
Re: A German is trying to invade my Japanese territoryHi Steve, no it was from the dipstick to the air box.
Fixed all the leaks now, I didn't do anything with the vacuum unit though as it turned out to be the actual vacuum pump, I think the vac leak from it might be a pressure relief so I left it alone for now, with the relief plugged and then retested I couldn't find any more leaks, I did check under the manifold where you mentioned Steve and seems to be all ok This German is getting a bit annoying now as I had to take the mazda out so I could get the slk in the shed, now it's pissing rain on the poor mx5
Re: A German is trying to invade my Japanese territoryThe German is gone, replaced by a honda
2007 1.4 se, something has to take the empty space in the driveway Sent from my ELE-L09 using Tapatalk
