I've a rear spring broken in the MK2, anyone have one knocking about?
MK2/NB rear shock and springI've a rear spring broken in the MK2, anyone have one knocking about?
![]() Re: MK2/NB rear shock and springI've some off mk1 if any use
Re: MK2/NB rear shock and springThanks pops, different size and rate I think though.
![]() Sent from my Redmi Note 5 using Tapatalk
![]() Re: MK2/NB rear shock and springHave 1 rear spring that is supposed to be from a mk2, you're welcome to it if it helps, don't know if it shows in the picture but it has 2 blue dots
![]() ![]() Sent from my ELE-L09 using Tapatalk
Re: MK2/NB rear shock and springCool will double check! Thanks
![]() Re: MK2/NB rear shock and springI've looked, but can't find dots, will give them a good scrub and see tomorrow.
![]() Re: MK2/NB rear shock and springSteve, if you're passing anytime call in and bring it with you, if it works you're welcome to it
Re: MK2/NB rear shock and springSound, I think Ian (softtop) might be out your way soon actually, thanks v.much
*edit just found this so I don't think it'll work as I've the SPORT-S. I just grab one online, thanks again for the offer though. "Hard-S yellow bilsteins have - two WHITE dots in the FRONT - two LIGHT BLUE dots in the REAR" SPORT – S Springs = 162lb/in (green dots) front, 118lb/in (purple dots) rear
![]() Re: MK2/NB rear shock and springI'll leave it inside the side gate incase I'm gone out, you're mk2 looks very nice
Re: MK2/NB rear shock and springWhoops, I'd been off editing when you replied
![]() Re: MK2/NB rear shock and springNo worries Steve
Re: MK2/NB rear shock and springpicked one up on ebay last Friday, will see how it goes
