Is my diff in trouble??
Postby leamyj » Tue, 22 Jul 2008 7:02 +0000
Have noticed lately when I turn to the right there is a roughness coming back from the car, if that makes sense? Doesn't occur when in straight line or turning left....any ideas what it might be?? I suspect the diff but wouldn't be qualified to say for sure :( :( :(
Postby Ivan » Tue, 22 Jul 2008 9:19 +0000
could be a wheel bearing
Postby mx5ash » Tue, 22 Jul 2008 2:27 +0000
Sounds more like a bearing to me to, drain the diff oil and check for any metal fragments if you want to check out the diff. (undo the refill (top) plug first to make sure it isn't stuck or you will be in trouble)
Postby leamyj » Tue, 22 Jul 2008 7:20 +0000
Thanks guys, I'll get the bearing checked out a.s.a.p.
Postby Stig » Wed, 23 Jul 2008 2:37 +0000
The diff seemed to be in perfect working order last monday evening John,in the loose gravel up the blooms :shock: :D :D
Postby leamyj » Wed, 23 Jul 2008 5:48 +0000
[quote="Ollie Brady"]The diff seemed to be in perfect working order last monday evening John,in the loose gravel up the blooms :shock: :D :D[/quote
:lol: :lol: :lol: :lol:
Postby Fergus » Mon, 28 Jul 2008 12:30 +0000
Bearing or cv joint/drive shaft.
