They wont raise when using the stalk to flash or turn on, but they will raise using the centre switch. The lights are coming on.
I've checked all the connections around the light motor, what else could it be? blown flash to pass diode?
 lights go up , lights go downI removed my charcoal cannister the other night and hey presto! my lights went loo la........
 They wont raise when using the stalk to flash or turn on, but they will raise using the centre switch. The lights are coming on. I've checked all the connections around the light motor, what else could it be? blown flash to pass diode?
 it does nothing! the lights just starting working again hmm!!!! must have been a dodgy connection
 k not totally sure my self but I think it has something to do with filtering the fumes from the intake?. its not essential and to be honest I think it looks better without it....   see here! http://www.mx5nutz.com/forum/index.php?showtopic=15120
   It stores/reburns petrol vapor emmissions from your tank(some of the worst kind).
 Don't do it if you park in a garage/smoke
 how will it cause extra smoke if no open connections are left?
   Is there a earth over that side of things somewhere that you could have disturbed.  http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
| Who is onlineUsers browsing this forum: No registered users and 7 guests | ||
