I need to get alignment settings for a 90 1.6 roadster.
in a hurry if possible.
the info from different sites seems to be conflicting.
import alignment settingsI need to get alignment settings for a 90 1.6 roadster.
in a hurry if possible. the info from different sites seems to be conflicting. ger
top of this page any good to you.
http://www.mx5ireland.com/forum/viewtop ... &start=165 ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Not sure deccy has a mk2.
Why you need them? the garage doing an alignment should have them no? ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
The 'Eunos Roadster Mk1' alignment settings have been around for years, go to another garage that has up to date hardware
That garage must be using equipment which is REALLY old.
i know, had to get it done quick for the NCT, the wheels were all over the place. Brought down some settings and the guy didnt even knoe the symbols for degrees and minutes, he just watched the slider on the screen.
anyway after about 1hr 20mins we were as close to lanny settings as possible, at this stage i ws doing most of the work. had a caster problem with one of the front wheels, couldnt get it below 6, must be a bush on the way out. Its cornering well now but pulling slightly to the left, i hve 5.5 caster on the left and 6.2 on the right.
Glad your sorted mate (nearly) ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
might be a bush or a stretched alignment bolt.. trussville Mazda sells them for 5 USD or so AFAIR
The Alignment bolts are KNOWN to bend in the Mk1s, Mx5Parts have the 'upgraded' ones. I changed all of mine a few years ago and yeah, the fronts were warped !
Why is there a different between the Eunos and MX5 regarding these
settings ? I thought they would be all the same ?
Who is onlineUsers browsing this forum: No registered users and 13 guests | ||
