Bilstein front shock - mk1Anyone got a spare one in good condition going cheap.
![]() I still have my old ones, they were working fine on the front when I took them off.
(edit) at least from what I remember they were Bilsteins, I'll check in the morning.
![]() Cheers dude, let me know, Failed the nct on front shock imbalance.
Flew through everything else - and emissions where down on the previous test after fitting jrcai, ss exhaust and link ecu. Sweet. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
![]() Unfortunately, as it turns out I can only find 1 of the rear ones, I must have either given them away a long time ago or they got binned.....dunno why there is still one left in the garage though
![]() Bilstein ?Ash think i have standard short yellow bilstein on shelf, could give you no guarantee on reliability to pass test as its used, give me a shout if i can help, Paul
Short ones are for the rear afaik. May have to get one sent from uk. Cheers anyway guys
Agreed, I checked on Mx5Parts and the shorts one are for the back (spring sits half way down the main shock cylinder). Ah heck, I'll recheck the garage in the morning man !
![]() Are you not supposed to change shocks in pairs or is that just a ploy to get you to buy two shocks instead of one???
![]() John
![]() If your putting on a new one then yeah should always be in pairs but i reckon another used one should be ok.
![]() you should get away with it Ash.
I had a Golf Gti many moons ago and fitted just the 1 to to front with no issues. best of luck with your search. ![]()
![]() RE shocksASh, what i meant was i have a front shock its about 1/2 inch shorter than standard as it came from mazda speed set up "not a rear shock" i have lots standard fronts i thought you needed the mazda speed one, they are both there, P
This is what i am looking for
![]() Its a front bilstein shock as fitted to s specials etc, Not mazdaspeed shocks or std. If you have one how much? Cheers ash ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
