Bilstein front shock - mk1
Postby mx5ash » Sun, 15 Feb 2009 6:19 +0000
Anyone got a spare one in good condition going cheap.
Postby Fergus » Sun, 15 Feb 2009 10:50 +0000
I still have my old ones, they were working fine on the front when I took them off.
(edit) at least from what I remember they were Bilsteins, I'll check in the morning.
Postby mx5ash » Mon, 16 Feb 2009 10:56 +0000
Cheers dude, let me know, Failed the nct on front shock imbalance.
Flew through everything else - and emissions where down on the previous test after fitting jrcai, ss exhaust and link ecu. Sweet.
Postby Fergus » Mon, 16 Feb 2009 9:57 +0000
Unfortunately, as it turns out I can only find 1 of the rear ones, I must have either given them away a long time ago or they got binned.....dunno why there is still one left in the garage though :roll:
Bilstein ?
Postby MeathMazdaMan » Mon, 16 Feb 2009 10:20 +0000
Ash think i have standard short yellow bilstein on shelf, could give you no guarantee on reliability to pass test as its used, give me a shout if i can help, Paul
MeathMazdaMan
Postby mx5ash » Mon, 16 Feb 2009 11:05 +0000
Short ones are for the rear afaik. May have to get one sent from uk. Cheers anyway guys
Postby Fergus » Mon, 16 Feb 2009 11:29 +0000
mx5ash wrote:Short ones are for the rear afaik. May have to get one sent from uk. Cheers anyway guys
Agreed, I checked on Mx5Parts and the shorts one are for the back (spring sits half way down the main shock cylinder).
Ah heck, I'll recheck the garage in the morning man !
Postby leamyj » Tue, 17 Feb 2009 8:12 +0000
Are you not supposed to change shocks in pairs or is that just a ploy to get you to buy two shocks instead of one??? :shock:
Postby mx5ash » Tue, 17 Feb 2009 12:05 +0000
If your putting on a new one then yeah should always be in pairs but i reckon another used one should be ok.
Postby Stig » Tue, 17 Feb 2009 12:34 +0000
you should get away with it Ash.
I had a Golf Gti many moons ago and fitted just the 1 to to front with no issues.
best of luck with your search.
RE shocks
Postby MeathMazdaMan » Thu, 19 Feb 2009 9:39 +0000
ASh, what i meant was i have a front shock its about 1/2 inch shorter than standard as it came from mazda speed set up "not a rear shock" i have lots standard fronts i thought you needed the mazda speed one, they are both there, P
MeathMazdaMan
Postby mx5ash » Thu, 19 Feb 2009 11:29 +0000
This is what i am looking for
Its a front bilstein shock as fitted to s specials etc, Not mazdaspeed shocks or std.
If you have one how much?
Cheers ash
