lsd
lsd
Postby mx5ideways » Fri, 02 May 2008 6:51 +0000
quick question,just wondering if a 1.6 lsd would fit the 1.8?,was thinking of buying a 1.6 with aftermarket lsd for parts
mx5ideways
Postby mx5ash » Fri, 02 May 2008 7:33 +0000
The 1.6 is generally considered a weaker unit so not a route i would suggest.
Also if you get a 1.6 diff you will also need 1.6 half shafts and a 1.6 prop shaft as these are different lengths (longer) to 1.8 parts to account for the extra size of the 1.8 diff. Make sense.
HTH Ash
lsd
Postby mx5ideways » Tue, 06 May 2008 11:02 +0000
ok thanks ash,if i did get one so it might be better to sell it and get a 1.8 one,would be alot of work for one a little weaker
mx5ideways
Postby mx5ash » Tue, 06 May 2008 11:14 +0000
Yeah pretty much mate, can't see it being worth it especailly as you would need to remove the hubs etc. if you can get a 1.8lsd then you only need to remove the halfshafts at the diff end, drop the diff and put the new one in. Easy!!!!
Postby Sean » Thu, 08 May 2008 11:49 +0000
Am i the only one who thought this post was about LSD? :?
Sean og
Sean
Postby leamyj » Thu, 15 May 2008 9:08 +0000
Sean wrote:Am i the only one who thought this post was about LSD? :?
Ah come on Seán, we've had decimilisation , the punt and the €uro since £.S.D. :P
(Anyone under 40 will probably not get that one)
Postby fabfiveferg » Fri, 16 May 2008 9:13 +0000
LMAO Sean. I did actually get confused by that one before.
I thought these people are CRAZY. No way can you drive effectively on acid :shock:
be woth a try I suppose.
Tunnel run anybody :wink:
Postby Sean » Fri, 16 May 2008 1:26 +0000
I can just picture everyone driving through the tunnel looking at the palms of their hands! LOL :lol: :lol: (eh,that was a joke officer!)
Sean og
Sean
