Door Pull
Door Pull
Postby notch000 » Sat, 17 Feb 2018 11:33 +0000
The cable looked to have snapped or stretched excessively on my drivers door, The doors stuck closed, is there any way to get the door card off from the inside without cutting wiht the door card off ?
notch000
Re: Door Pull
Postby Pops » Sun, 18 Feb 2018 5:33 +0000
Not too sure , but if you lower the door glass fully you might be able to get a long screwdriver or coat hanger at the mechanism.
Are you sure it’s unlocked ( don’t know what model you have) in the mk1 sometimes the key turns in the lock but doesn’t open it
Re: Door Pull
Postby Pops » Sun, 18 Feb 2018 5:52 +0000
This should help. It seems though that now the spring can be got on its own,
http://www.mazdamenders.net/index.php/f ... -open.html
Re: Door Pull
Postby 93 Mk1 » Sun, 18 Feb 2018 10:12 +0000
This happened to me a few years ago and it was indeed that spring that caused the problem. I bought the replacement from MX5 Parts I think.
93 Mk1
Re: Door Pull
Postby Steve » Mon, 19 Feb 2018 5:59 +0000
some detail in here might help :
viewtopic.php?f=12&t=3458&p=29912&hilit=lock+spring#p29912
viewtopic.php?f=9&t=6288&p=51686&hilit=lock+spring#p51686
I do remember using the spring from a pen until the part arrived.
