Users browsing this forum: Bing [Bot] and 26 guests
Door PullThe cable looked to have snapped or stretched excessively on my drivers door, The doors stuck closed, is there any way to get the door card off from the inside without cutting wiht the door card off ?
Re: Door PullNot too sure , but if you lower the door glass fully you might be able to get a long screwdriver or coat hanger at the mechanism.
Are you sure it’s unlocked ( don’t know what model you have) in the mk1 sometimes the key turns in the lock but doesn’t open it
Re: Door PullThis should help. It seems though that now the spring can be got on its own,
http://www.mazdamenders.net/index.php/f ... -open.html
Re: Door PullThis happened to me a few years ago and it was indeed that spring that caused the problem. I bought the replacement from MX5 Parts I think.
Re: Door Pullsome detail in here might help :
viewtopic.php?f=12&t=3458&p=29912&hilit=lock+spring#p29912 viewtopic.php?f=9&t=6288&p=51686&hilit=lock+spring#p51686 I do remember using the spring from a pen until the part arrived.
Who is onlineUsers browsing this forum: Bing [Bot] and 26 guests | ||
