cigarette lighter broken
Postby fabfiveferg » Tue, 13 May 2008 4:18 +0000
there appears to be no power coming from the ciggie lighter pod. I have tried changing the fuses but to no avail.
Anyone any ideas for a plan B cause I'm stumped.
Postby leamyj » Tue, 13 May 2008 6:09 +0000
Check power at terminals on rear of lighter socket. ?
Postby Fergus » Tue, 13 May 2008 6:12 +0000
Probably an extra inline fuse along the wire somwhere.
Postby fabfiveferg » Wed, 14 May 2008 10:54 +0000
Thanks lads. I'm flippin useless when it comes to the electrics.
I'll check for a line fuse later. Hopefully it's as simple as that
Postby Ivan » Wed, 14 May 2008 11:27 +0000
stop smoking
Postby fabfiveferg » Wed, 14 May 2008 12:36 +0000
Ivan that's brilliant.
Still not sure how I'll power my Sat Nav though. Any wisecrack ideas at all?
No?
Nothing? :idea:
Postby leamyj » Wed, 14 May 2008 1:28 +0000
Is there a fuse in your sat nav cig lighter adapter? Have you tried any other gadget in the cig lighter socket?
Postby fabfiveferg » Wed, 14 May 2008 3:37 +0000
I've tried the ciggie lighter and the satnav.
Postby Steve » Wed, 14 May 2008 4:41 +0000
Best to get a multimeter on the wires at the back of the lighter socket to see if you are getting power.
Postby Ivan » Thu, 15 May 2008 8:13 +0000
fabfiveferg wrote:Ivan that's brilliant.
No?
Nothing? :idea:
Buy a map
Postby Reesy » Mon, 19 May 2008 9:37 +0000
The connections / element on my cig lighter were all corroded & crap which was causing mine to fail... but I guess you'd have seen that, Ferg?
Simon
Reesy
