Diff half shaft seal gone again.I changed the passenger side diff oil seal a few months back.
I havent been doing any overly agressive driving but its seams worse than ever. The oil has gone everywhere. Would there be anything that could cause this. Think i heard something about a vent on these that can get blocked. The car is a 1.8 MK1 with tonsion lsd. Anyone able to shead some light on this? Andy
Re: Diff half shaft seal gone again.Are the shafts ok? They can get rusted up which would shred the Seal.
Re: Diff half shaft seal gone again.Or any sort of mark on the shaft can cause the same
Re: Diff half shaft seal gone again.You'll forgive me if I'm talking rubbish here - my wife has only owned her MX5 for 9 months and I'm not that familiar with them - yet
All the best, Neil.
Re: Diff half shaft seal gone again.The shafts are perfect. The part that goes into the diff look brand new.
If there is a bearing or bush gone is it cost effective to fix or should i be on the lookout for a new diff?
Re: Diff half shaft seal gone again.The Seals will take up lots of play, but if bearings are gone its no big deal. They are standard taper roller bearings and easily got. I'm more concerned as to who fit the seals. They are easily damaged during insertion and by the c clip ripping a piece out of them.
Re: Diff half shaft seal gone again.Well I fitted the last one. Might get my mate whos a mechanic to do this one.
Either that or we could try organise a tech day.
Re: Diff half shaft seal gone again.Do probs with that. Come up to me any saturday.Near Drogheda.
Re: Diff half shaft seal gone again.Might have to take you up on that.
Have the seal ordered now.
Re: Diff half shaft seal gone again.3 weeks to get in the diff seal of mx5 parts. Must be a fairly common part to go.
Re: Diff half shaft seal gone again.If you have an old seal orytake a seal out you can more than likely get a set in an agri spares shop. I can give you measurments monday if you need
Re: Diff half shaft seal gone again.Balls, i can get them if needed.
Re: Diff half shaft seal gone again.Check autolinks.co.uk
Re: Diff half shaft seal gone again.I have a supplier in Dublin if your stuck. Not a stock item so had to get them special order due to the extra wiper lip on them.
Re: Diff half shaft seal gone again.Its not coming out too quickly. Only getting a small bit of oil into the diff every 3-4 days. Not even taking a full 100ml.
I have it ordered and if it gets worse ill take it off the road till I get it. Just no big long drives thats all. Lol
