Software for IPAQ to run Link datalogging.Lads , have datalog programme downloaded but it doesn't seem to want to work on the ipaq. Someone was probably using this before and has experience of it so what im looking for is a programme/software to allow the ipaq to er, datalog.
Anyone? The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: Software for IPAQ to run Link datalogging.I def had a copy but the harddrive it was on died... I'll have a look, probably have it backed up. Took me ages to find it online again last time I went looking.
Re: Software for IPAQ to run Link datalogging.Big help if you can Steve, thanks.
Re: Software for IPAQ to run Link datalogging.I believe the software is hw.exe by Matt Rhoten.
Re: Software for IPAQ to run Link datalogging.yeah, saw your post, I tried contacting the dude who sent it on to me initially but his email address doesn't exist anymore. Also pinged Frank, he's going to have a look too in his archives.
Think the exact name of the zip was : hw-ppcarm.zip (it contained the hw.exe file amongst others). Have emailed the miatapower mailing list to see if anyone on there has a copy still too.
Re: Software for IPAQ to run Link datalogging.Thanks Steve. Have tried to contact Matt but no reply yet.
Re: Software for IPAQ to run Link datalogging.Sorted with the help of Keith Tanner . Steve if you want the links to it ill post them.
Re: Software for IPAQ to run Link datalogging.excellent, yes please
Re: Software for IPAQ to run Link datalogging.Tis all here..........
http://www.flyinmiata.com/support/HW/ReadMe.txt http://www.flyinmiata.com/support/HW/hw.exe No way anyone would find this on the FM site. The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: Software for IPAQ to run Link datalogging.nice one.
BTW, I had trouble connecting the ipaq initially, it was the cable in the end, needed to use a lot of male/female adaptors to get the right serial cable setup combination. Let me know if you have similar issue and I'll list what I've been using.
Re: Software for IPAQ to run Link datalogging.Ill try it tomorrow Steve and report.
Re: Software for IPAQ to run Link datalogging.Steve,
everything works ok and i can view all the files/ logs but i cant seem to view the log i saved today. Basically the one stored in the ecu is not "viewable" either on the ipaq or when i connect it to my pc. Says its a bin file or something. Am i correct in thinking that i can change settings in the map/file using the ipaq only or is there something else i need to download? Also, are there any instructions on the hw file? The read me is vague at best??? The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: Software for IPAQ to run Link datalogging.Are you using DataLogLab? Its free now and FM are hosting the old site :
http://www.flyinmiata.com/dataloglab/ So, when you have the ipaq hooked up, engine running and data changing in realtime in the display, there should be a "start" (or similar) button near the bottom to kick off a data logging session. Let this run for about 2 mins and then click "stop". Save the file as a txt file using the file conversion option. You should be able to import that file into DLL now on your pc. I'll email you a log now, I took it a couple of years ago, so you can see the expected output/format.
Re: Software for IPAQ to run Link datalogging.Yeah, did it again and did a quick start stop and i got it downloaded. It saved it ok as a .txt. Viewed it thro DLL and all the info came up bar the 3 bottom fuel rows although they show on the IPAQ screen.
Can you change any settings on the ipaq or do you have to do it on DLL and send it back to the ipaq? As I said , the instructions on the read me file are shite!! The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: Software for IPAQ to run Link datalogging.Ah lads, my head's hurting here trying to follow the thread
