Re: Turbo tuning
Postby andrew » Wed, 20 Nov 2013 12:15 +0000
Good to see some interest in FI with these cars. Stuart its not as hard as it sounds. As Rhys said, start reading. All the info is on the web, start by ordering a mega squirt for a guy called Reverent on nutz or miata turbo. Sometimes he does group buys which reduces the cost. the ECU will take a few week to arrive, this gives you time to source the other parts. There is a guy on nutz called Sturovo who is making turbo kits, manifold, down pipe, oil and water lines for £400 odd quid. Notice I said 'kit'. Plug and play mega squirt and a turbo kit is fairly simple to install. If you get stuck there is help on here or a local garage should be able to complete it. Intercoolers are available as 'kit's too.
I think the hardest part of mine was the injectors as I had to rewire the injector loom. Again Reverent will advise if this is necessary. I wouldn't buy second hand injectors or an ECU, if these are faulty they will break your heart and possibly car. Its not worth it.
Mine will probably be off the road at the end of the month so if you want to see one let me know.
andrew
Re: Turbo tuning
Postby rhysmate » Wed, 20 Nov 2013 12:40 +0000
If there was a tech day id go and help as best i can
With regards to injectors, i have rx7 460cc redtops and at almost a bar the duty cycles is below 80% so theyre more than good enough. They were only 100 dollars off a dude in the states.
Didnt know Sturuvo made kits. His car is insane
All of the advice above is spot on. These guys know their stuff :)
rhysmate
Re: Turbo tuning
Postby Randy » Wed, 20 Nov 2013 1:37 +0000
I really need to get on these sites.. Been lagging behind in my research as I ran into an issue with my diff, but all this is valuable knowledge.
Will be reaching out to Reverent about a megasquirt for the car soon. :)
Randy
Re: Turbo tuning
Postby fez » Wed, 20 Nov 2013 5:21 +0000
Randy wrote:I really need to get on these sites.. Been lagging behind
intentional pun?
fez
Re: Turbo tuning
Postby Randy » Wed, 20 Nov 2013 6:05 +0000
intentional pun?
Afraid not, man. ;)
Randy
Return to Engine Mods
