Good to see some interest in FI with these cars. Stuart its not as hard as it sounds. As Rhys said, start reading. All the info is on the web, start by ordering a mega squirt for a guy called Reverent on nutz or miata turbo. Sometimes he does group buys which reduces the cost. the ECU will take a few week to arrive, this gives you time to source the other parts. There is a guy on nutz called Sturovo who is making turbo kits, manifold, down pipe, oil and water lines for £400 odd quid. Notice I said 'kit'. Plug and play mega squirt and a turbo kit is fairly simple to install. If you get stuck there is help on here or a local garage should be able to complete it. Intercoolers are available as 'kit's too.
I think the hardest part of mine was the injectors as I had to rewire the injector loom. Again Reverent will advise if this is necessary. I wouldn't buy second hand injectors or an ECU, if these are faulty they will break your heart and possibly car. Its not worth it.
Mine will probably be off the road at the end of the month so if you want to see one let me know.
