Cam angel sensor questions
Postby tomtom2004 » Tue, 04 Feb 2014 6:14 +0000
I just bought a 92 1.6 import . It has a few problems and came with some parts the previous owner had purchased but never fitted.
One of this parts is a used cas with 93. And 1.6. Written on it obviously from breakers. I tried to fit this today but I couldn't get it to sit home I though because I could not line up the key , however when I refitted the original sensor I took out I could get that to sit home quite easily .
Is there a knack in lining up the key to the cam and is it possible that the part is the wrong one. The sensors don't look exactly identical but the part that goes into the can does to the eye.
tomtom2004
Re: Cam angel sensor questions
Postby MX5Spares » Tue, 04 Feb 2014 6:37 +0000
It could be 1.8 cam sensor as the fitting is the same but the body is slightly different shape. We have 1.6 sensors if you need one.086 8226506
Postby tomtom2004 » Tue, 04 Feb 2014 7:45 +0000
Cheers autocheck. I'd say it is the 1.8. one I have. I will try fit it again now that I know it should fit. I got a new Feul pump and filter , I will fit those parts to see where that leaves me and I will the be calling on you for sure. Do you have any style bars for the mk 1
tomtom2004
Postby MX5Spares » Tue, 04 Feb 2014 10:13 +0000
Some coming in soon as the ones I have are sold. We had two lately 086 8226506
Postby back_in_black » Tue, 04 Feb 2014 11:35 +0000
Hi tomtom and welcome.
The part that goes into the cam can only fit one way to avoid being 180 degrees out. Good idea to put a new oil seal on the CAS when putting it in. Common place to have an oil leak.
back_in_black
Postby Yolo » Wed, 05 Feb 2014 12:40 +0000
back_in_black wrote:Hi tomtom and welcome.
I agree it was the first job I did on mine.... Easy if you already have it removed and saves hassle in the long run for the sake of a few pence.
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby tomtom2004 » Wed, 05 Feb 2014 3:31 +0000
Cheers That could explain why i couldn't get it to fit, I will get a new oil seal too, would that be a dealer or motorfactor part.
Thanks for the help, I appreciate it.
tomtom2004
Postby Yolo » Wed, 05 Feb 2014 11:11 +0000
You can get them in either and aren't expensive.
As for a style bar I have an original Mk 2 bar and wind deflector that I never fitted but understand it fits the Mk 1 if you are interested.
Mk2 suspension
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
Yolo
Postby tomtom2004 » Thu, 06 Feb 2014 1:14 +0000
Thanks for the advice, yes I'm interested in the style bar . Is it This one http://thumbsnap.com/1ZmDIKtY.
Pm me a price and contact number and I'll give you a call
Tom
tomtom2004
