gearbox trouble
gearbox trouble
Postby sean4344 » Mon, 15 Sep 2014 11:19 +0000
i have a 1.8 mk1 with a 5 speed box. for d last few weeks its bin whining really loud on acceleration, it goes into all the gears fine tho. im thinking the bearings are gone, am i right? do i need to change the box r can i just replace the bearings?
sean4344
Re: gearbox trouble
Postby Steve » Mon, 15 Sep 2014 11:44 +0000
could be just the release/spigot bearings. Any crunching going on?
Re: gearbox trouble
Postby rhysmate » Mon, 15 Sep 2014 1:45 +0000
Might be something to do with your avatar ;)
As Steve said the spigot bearing makes alot of noise when it dies. Anything else amiss?
rhysmate
Re: gearbox trouble
Postby scallan » Mon, 15 Sep 2014 3:28 +0000
I had similar trouble and turned out to be the spigot bearing. Its in the middle of the flywheel so box out job.
Its a 6202 bearing try get a good quality 1or if there is a john deere tractor dealer near ask them for the spigot bearing for a 3050
scallan
Re: gearbox trouble
Postby rhysmate » Mon, 15 Sep 2014 7:34 +0000
scallan wrote:I had similar trouble and turned out to be the spigot bearing. Its in the middle of the flywheel so box out job.
Great info! have you one of those in the car now?
rhysmate
Re: gearbox trouble
Postby MX5Spares » Mon, 15 Sep 2014 7:38 +0000
We have good used mk2 boxes which will fit and have lower mileage .
Re: gearbox trouble
Postby scallan » Mon, 15 Sep 2014 8:41 +0000
Oh i do as i work as a storeman in a john deere dealership haha
scallan
Re: gearbox trouble
Postby sean4344 » Tue, 16 Sep 2014 11:39 +0000
everything else seems fine just the noise is unbearable
sean4344
Re: gearbox trouble
Postby sean4344 » Tue, 16 Sep 2014 11:41 +0000
autocheck wrote:We have good used mk2 boxes which will fit and have lower mileage .
how much u talkn? are they 5 r 6 speed?
sean4344
Re: gearbox trouble
Postby MX5Spares » Tue, 16 Sep 2014 3:45 +0000
pm sent
