difference in enginesim hearen a rumour that the mazda mx5 mk1 1.6 has the same engine as the 323 is this correct?or is there small difference between them?all replys welcome
Re: difference in enginesIt has the same block as the 323 turbo, but the pistons are higher compression & rods are lighter. </nerd>
Re: difference in enginesOnly you would've had the answer to that one Steve - good on ya!
Re: difference in enginesbut say could u use the raidiator for mx5 off the 323?
Re: difference in enginesNope, the mountings are different what with the 323 being FWD etc
Re: difference in enginesso is there a nother raidiator i could use?
Re: difference in enginesdoubt it, but check here: http://www.miata.net/garage/garageengine.html
and especially here: http://www.miata.net/garage/radiator/index.html It's a small world after all. It's a small, small world
